v1.01a troubleshooting (no display, but seq. is good)
Posted: Jun 4th, '19, 17:14
Hi there
So, I was building the Nava quite a while ago, but I had to move and many other things got in the way and I finally have time to sit down and work on it again, but I am stuck as there is some things that are not working properly.
My display isn't working, though the backlight does. My sequencer looks to be working, LEDs light up, I can program patterns etc, but I have no sounds on the only two voices that I have built - BD and SD.
I do not have 5v at TP1 no matter if I turn TM2. Not with analogue ground or any other ground.
I am a bit confused because I don't have 1.0 or 1.02 - I have 1.02a just between, so for instance the whole R40 thing that I see people writing about; i dont know what to do.
I have tried checking for bad solder joints on my display and the Atmega chip, but haven't found any that seems to need resoldering.
I am asking for advice on how to proceed and where to look for faults, and why I don't seem to have any voltage at TP1..
Sorry if this is a bit vague, but since I haven't worked on it for very long; I am looking for clues and explanations for the difference between the different version and especially what to focus on with 1.01a..
Thank you in advance.
