Page 1 of 2
HandClaP/MAracas section just leak noise...
Posted: Jan 25th, '19, 18:41
by bsas
So, after everything is done and it is working, the only issue I am having is with the Handclap.
Basically, unless my TM3 is at the minimum, the noise is unbearable (it is louder then the effect). Even TM3 at minimun there is a lot of noise.
Even if the effect is NOT in the song at all, just if the Handclap volume is not at zero, the noise is present (the noise leaks even in the volume below the "orange" reference point, below noon). The noise is present on the master and also on the individual output. If the track is CLEAR but I just move the Handclap volume the noise leaks.
So, any idea where in the circuit this noise is "not being blocked" or filtered? Looking at the schematic I am guessing the U21B section but it is a long guess and I have no idea how to debug this...
Thanks!!!
Re: HandClaP/MAracas section just leak noise...
Posted: Jan 25th, '19, 19:38
by bsas
Just tried to switch the BA6110 and all 4558s with the PC2 section (since I socketed all ICs and the PC2 is working perfectly) and the noise still there. So, my guess is that it is not the ICs at all.
No idea what it can be, but it is obviously the "WN" section (the noise section) leaking since if I change TM4 the noise changes. I am pretty sure that TM4 is correct since my TP4 is measuring exactly 130mV RMS. Also, the noise is used for other instruments and they sound correct and they don't leak...
Posted: Feb 3rd, '19, 22:03
by bsas
FIXED!!!
Answer directly from Vincent by email:
"It seems that the AN6912 is dead.
Try to replace it with a stantd quad comparator like LM339"
That worked like a charm! While I am trying to source an working AN6912 for "authenticity", the sound of the handclap now is amazing and I am glad that I socketed all ICs.
Posted: Sep 16th, '25, 08:14
by will
brother printer drivers are software programs that allow your computer or device to communicate with and control Brother printers for smooth printing and scanning operations.
software programs that enable smooth communication between your computer or mobile device and the Brother printer, ensuring accurate printing, scanning, and other functions is known asbrother printer drivers
software that serve as a translator between your brother printer drivers and your computer or device, allowing printing, scanning or other functions to work properly.
brother printer drivers are essential software that enable smooth communication between your computer or device and a Brother printer, ensuring accurate print commands, compatibility, and access to advanced features like scanning, wireless printing, and troubleshooting support.
brother printer drivers are software that enable communication between your Brother printer and computer for smooth printing and scanning.
Posted: Sep 16th, '25, 08:16
by will
brother printer drivers are software translators that let Brother printers/labellers/scanning/sewing machines understand the data your computer sends (for documents, images, etc.) so they print/scan correctly.
brother printer drivers are software programs that allow your computer or device to communicate with Brother printers, ensuring smooth printing, scanning, and connectivity functions.
Software that acts as a translator between yourbrother printer drivers and your computer or device, enabling smooth printing, scanning, and other functions.
brother printer drivers are software that connect your printer to your computer, ensuring proper functionality and performance.
Posted: Sep 16th, '25, 08:17
by will
Installing Epson Printer Drivers properly is the main part to getting your Epson printer working without issues. If you're using a Windows PC or a Mac, this guide teaches you through every step clearly and simply to download and install Epson Printer Drivers.
Epson Printer Drivers are essential software programs that enable communication between your computer or device and the Epson printer, ensuring smooth operation of functions like printing, scanning, and advanced settings.
Epson Printer Drivers are software that connect your printer to your computer, enabling printing, scanning, and other functions.
Epson Printer Drivers are software components that let your computer communicate with an Epson printer, translating document data into a format the printer can understand.
Before you begin installing Epson Printer Drivers software, you must first connect the printer to the network so that it can be used from a computer. Simply follow the instructions in the manual to set up the printer and connect it to the network.
Posted: Sep 16th, '25, 08:20
by will
Epson Printer Drivers are software that let your computer communicate with Epson printers, managing print jobs and printer settings.
Posted: Sep 19th, '25, 11:43
by Rosy desk
Activate your UnitedHealthcare member ID card online at Activate.uhc.com quickly and securely.
Visit Activate.uhc.com to set up your UHC card and access health benefits today.
Get your UnitedHealthcare card ready for use by completing activation at Activate.uhc.com
Manage your UHC health plan with ease—start by visiting Activate.uhc.com to activate your card.
Fast and secure card activation is available at Activate.uhc.com for UHC members.
Posted: Sep 19th, '25, 11:52
by Rosy desk
To unlock health coverage benefits, complete activation atActivate.uhc.com
UnitedHealthcare members can activate their ID cards online at Activate.uhc.com.
Log in to Activate.uhc.com and follow the easy steps to activate your card.
Quick card setup for UnitedHealthcare plans is available at Activate.uhc.com
Enjoy convenient access to UHC services by activating your card atActivate.uhc.com
Posted: Sep 19th, '25, 11:53
by Rosy desk
Visit Activate.uhc.com and get your healthcare card activated today.
To manage your UHC health coverage, activate your card at Activate.uhc.com
Enjoy peace of mind with quick card activation at Activate.uhc.com
For fast UHC card activation, go to Activate.uhc.com now.
UnitedHealthcare cardholders should activate their cards online at Activate.uhc.com
