[Wish List] Yocto OS Update Thread
Posted: Feb 6th, '14, 13:56
				Hi everybody,
Let's tell what we would love to see in the next Software Updates!
And also a Bug Report if You ever find one...
-Shuffle / Groove
It would be awesome to set a groove values for each pattern!
-Solo /unSolo
Mute /unMute is a really clever and great function. The unMute with the Tempo Pot is perfect! I wish I could do exactly the same with a Solo / unSolo function. When you want to mute all the instruments tracks except the Kick in one push it's hard to perform!
-Stutter Function
Like the Volca Beat for instance! I don't know if it's even possible...but would be nice though!
-Random/Reverse Pattern
Could be a great function as well! With on button you switch the way the steps are played.
-Instruments Play
Like other TR-X0X, You could play and record a rhythm tapping your step buttons.
-Yocto Midi Slave and DinSync Master
Maybe it's only my Yocto, but I tried to sync a Tr-606 via the Yocto midi syncing and it didn't work. But it worked perfectly when the Yocto is not sync with midi.
-Pattern Edit
For now, You can't mute/unmute the instruments while editing a pattern. I like to play the Yocto while I'm editing in live pattern like fills for instance! Also it could be great if you could switch the pattern while editing. Chaining pattern for editing would ne nice as well!
Your turn Yocto Users!
-Shuffle / Groove
-Solo /unSolo
-Stutter Function
-Instruments Play
-Pattern Edit
