A few problems with my Yocto2
Posted: Jan 25th, '18, 11:03
So after a few weeks playing with it, here's some bugs I've found on mine:
- When using Din sync to send the Yocto clock to other drum machines, I've found that the clock starts lagging or is not steady when changing patterns. (Not on the yocto but on the slaved instrument)
- When linking two patterns (pressing two step buttons at once) it works for all pattern slots except when I press 9 & another step together. The sequencer plays the first step of the #9 pattern and then switches to the other pattern. (I don't know if that's clear
- When in tap mode at first all the currently playing instruments where blinking as they're supposed to but now they are not. It began after re-soldering some stuff around the bottom part of the PCB to make it fit the case. (Maybe it's linked to the problem above?)
Otherwise everything works and sounds great!
Thanks in advance for any idea
PS: I don't know if those problems are hardware or software related, so I post it here.
