Shuffle
Posted: Jan 10th, '14, 13:35
by effegee
Will shuffle be added in a future update?
Re: Shuffle
Posted: Jan 11th, '14, 11:15
Dear effegee,
It would be a great update. 8-)
Maybe you could start a new topic with all update people want.
best regards,
Re: Shuffle
Posted: Mar 26th, '15, 01:33
by olli
any luck with shuffle now?
did someone implement it yet?
if not
where in the sourcecode would the changings take place?
Re: Shuffle
Posted: Mar 30th, '15, 07:01
by deejayraoul
i didn't get to trying any coding yet. i started to dig into the code a bit to familiarise myself with the arduino environment.
i want to order myself a new cpu before i start to try and compile and load the binaries. i don't wan't to kill my perfectly working yocto by doing something stupid :).
so for me it's a long way before i'll start, i don't even know how to compile the code yet, let alone how to get it on the chip :)
once i start i want to make a functional design for the stuff i'd want to add and try to implement them step by step.
olli wrote:any luck with shuffle now?
if not
Re: Shuffle
Posted: Jun 11th, '15, 09:16
by misa
I know it's a (expensive) workaround, but using the Roland Aira syncbox as master, you can shuffle the Yocto with pleasure.
Re: Shuffle
Posted: Jun 17th, '15, 09:07
by rv0
If you have a x0xb0x with x0xlarge cpu mod running n0nx0x2, you can also shuffle outgoing clock (when x0x is master)
Re: Shuffle
Posted: Jul 23rd, '15, 15:35
by peteone43
you could use new beatstep pro $250
Re: Shuffle
Posted: Aug 22nd, '15, 23:19
by misa
ok. All workarounds notwithstanding. Where is shuffle? Will it be implemented? Please! Tanzmaus and Tanzbar light will have it -- like many others.
It would add so much to Yocto..!
