Page 1 of 2
Ext Instrument trigger just sends out two 'note off' message
Posted: Sep 12th, '17, 18:33
by 4teenth
As it say - I tried to play with this but had no success. Using MIDI monitor I found that each step that triggers the Ext instrument just sends out two note off messages.
Re: Ext Instrument trigger just sends out two 'note off' mes
Posted: Dec 21st, '17, 02:22
by 4teenth
Has anyone got this working?
Posted: Jan 2nd, '18, 07:01
4teenth wrote:As it say - I tried to play with this but had no success. Using MIDI monitor I found that each step that triggers the Ext instrument just sends out two note off messages.
4teenth,
We monitored with MIDIOX and we only have one MIDI Note OFF message and it works properly
Did you manage to get EXT Instrument working ?
Posted: Sep 13th, '18, 21:37
by 4teenth
I did previously, now I can't seem to get to the note input menu by holding inst select and guide. Shift and guide will allow me to input the triggers.
Posted: Sep 13th, '18, 22:11
by serum114
Press shift + Guide to place triggers. Press inst select + num to enter the note memory.
Posted: Sep 25th, '18, 20:38
by 4teenth
serum114 wrote:Press shift + Guide to place triggers. Press inst select + num to enter the note memory.
Yeah that works, god knows how I managed to do that previously as it's not written like that in the pdf manual I have. Also, it seem to not trigger the note off properly on my Behringer Model D, or at least the envelopes aren't retriggering. MIDI monitor shows there is a note off trigger before the next note so not sure what's happening there. It's fine on my Juno 106, although the last note will hang if I press stop.
Finally, what's the best way of using it? 303 style random notes etc and hope for the best? Or figure out a bassline and then figure out how to program it in?
Posted: Sep 25th, '18, 21:27
by 4teenth
Hmm it seems that actually with 16th notes even the Juno doesn't always trigger. And recording the output into ableton and playing it back shows it's a problem with the gap between note off and the next note playing, as the same problem occurs if I just draw in a load of 16th notes in a pattern. :/
Posted: Sep 25th, '18, 21:49
by 4teenth
Ahhhh I was on an older version of the firmware. Updated to 1.023, seems a bit better, most notes trigger on the Juno, but with a slight latency :( I see there was a fix on some newer firmware that changed the ext trigger time, I'm guessing this is related to my issue? Trouble is I never got my MUX board :(
Re: Ext Instrument trigger just sends out two 'note off' message
Posted: Sep 19th, '25, 07:24
by will
Yt.be/activate is the link used to connect YouTube to your smart TV or streaming device.
Easily pair your YouTube account with your TV by visiting Yt.be/activate
Yt.be/activate is the online activation page for YouTube on smart screens.
Use Yt.be/activate to enter your code and link YouTube to your device.
Yt.be/activate helps you enjoy YouTube on big screens without logging in manually.
Posted: Sep 19th, '25, 07:25
by will
Activate YouTube on streaming devices by visiting Yt.be/activate and entering the code.
Yt.be/activate makes YouTube setup quick on TVs and consoles.
Enter your activation code at Yt.be/activate to link YouTube instantly.
Yt.be/activate is the shortcut to pair your YouTube account with supported devices.
Watch YouTube on your TV by activating it through Yt.be/activate
