Hey all,
Does the Yocto have midi notes assigned for Trigger 1 and Trigger 2? ...That way I can trigger the triggers from Ableton. If you point me in the right direction, I'll figure it out...
Thanks,
David
Trigger 1 Trigger 2
You mean you're in MIDI expander mode and want to send MIDI notes that trigger TR1 and TR2 on the Yocto? I haven't tried but I assumed you could assign MIDI notes to those just like with the other instruments (hold down shift and send the MIDI note to the Yocto to assign it to the currently active instrument), but looking at the source it seems it's not implemented.
However I found this in the source:
I'm no expert but it looks like the MIDI notes for TR1, TR2 are hard coded to notes 60 and 62. Give that a try!
If everything fails it seems quite easy to modify the code to include those triggers in the regular assignment procedure.
Code: Select all
inst_midi_note[0]= 59; //Array des note midi de chaque instruments
inst_midi_note[1]= BD_MIDI_NOTE;//Array des note midi de chaque instruments
inst_midi_note[2]= SD_MIDI_NOTE;//Array des note midi de chaque instruments
inst_midi_note[3]= LT_MIDI_NOTE;//Array des note midi de chaque instruments
inst_midi_note[4]= MT_MIDI_NOTE;//Array des note midi de chaque instruments
inst_midi_note[5]= HT_MIDI_NOTE;//Array des note midi de chaque instruments
inst_midi_note[6]= RM_MIDI_NOTE;//Array des note midi de chaque instruments
inst_midi_note[7]= HC_MIDI_NOTE;//Array des note midi de chaque instruments
inst_midi_note[8]= CW_MIDI_NOTE;//Array des note midi de chaque instruments
inst_midi_note[9]= CY_MIDI_NOTE;//Array des note midi de chaque instruments
inst_midi_note[10]=OH_MIDI_NOTE;//Array des note midi de chaque instruments
inst_midi_note[11]=CH_MIDI_NOTE;//Array des note midi de chaque instruments
inst_midi_note[12]=60; //Array des note midi de chaque instruments
inst_midi_note[13]=62; //Array des note midi de chaque instruments
inst_midi_note[14]=64; //Array des note midi de chaque instruments
inst_midi_note[15]=65; //Array des note midi de chaque instrumentsIf everything fails it seems quite easy to modify the code to include those triggers in the regular assignment procedure.
