IC CD4011BE from tayda not Unbuffered (CD4011UBE)
Posted: Nov 23rd, '16, 09:55
by zephyrin
Hello,
I have a trouble withe the ride instrument. I have read for the 9090 that IC 4011 for HH, Ride and Crash must be the 4011U.. (unbuffered)
I have check the bom for Mouser and the 3 IC are correct (CD4011UBE( but in the Tayda Bom there a link to the CD4011 CD4011BE
Tayda link
http://www.taydaelectronics.com/cd4011- ... te-ic.html
I have not confirmed that my trouble come from the wrong IC because i need to buy 3 good 4011 IC
PS : Tayda have only CD4011BE
Re: IC CD4011BE from tayda not Unbuffered (CD4011UBE)
Posted: Nov 23rd, '16, 14:49
by redstorm
The same situation for me, somewhere between "fun" and "ridiculous" now, when the second china seller send me CD4011BE instead of CD4011UBE... So i have 33 *BE chips now (lol), first 3 was in tayda order, then ordered 20.. ..and then another 10... More than 2 months passed while waiting the packages to arrive... and still waiting for next, and i hope the last, iteration of *UBE chips orders to arrive. Although, even when im intentionally not very fast with the build, at this moment i would say, 90% is finished, so only sequencer is left.
I was thinking that if i would assemble it faster than *UBE chips will arrive, i will simply try to change time constants in generator circuit by changing R493, R442, R440 resistors to achive needed samplerate. But the "build motivation" fallen down a bit when i received the second iteration order with the wrong IC's.
Now i think that the best solution is to simply plug the appropriate IC there.
Posted: Nov 23rd, '16, 15:15
by zephyrin
This is an explaination by trevor with the 9090
The clock circuits in the crash, ride and hi-hat circuits each require a 4011 quad NAND IC, and this IC must be an un-buffered
type for the oscillator to work correctly. That is, the part number must contain 4011U. Typical part numbers may therefore be 4011UB, 4011UBE and so on. A buffered
type i.e. 4011B, etc. is not suitable.
You can put the 4011BE instead of 4011UBE in my case only the ride seem no good , but i will changed the 3 IC of course when i will recieved it.
Thii iy my ride
