Distorted kick through main mix [SOLVED]
Posted: Oct 3rd, '16, 19:51
by 4teenth
As it says - if I turn the kick up more than about 9 O'clock it sounds distorted through the main mix. Fine through the individual output though...
In case it is helpful to troubleshoot where I've maybe used the wrong component somewhere, I had the following components left over at the end (the numbers in brackets were the amount that were initially supplied, according to the mouser bags):
2 x 0.01uF Film (22x)
5x .1uF Film (7x)
1x 1N4148 Diode (95x)
4x 220R (8x)
1x 10K Resistor (138x)
2x 1K resistor
2 x 603 transistor
Re: Distorted kick through main mix
Posted: Oct 3rd, '16, 22:26
by 4teenth
Hmm seems I'd soldered one of the connectors from the IO board to the main board backwards like a doofus... Swore I'd double checked that too :o
