Crash debugging
Posted: Aug 25th, '16, 14:41
Hey everyone,
My crash was fine when I was done building the Nava, but a few days later, probably because I was using the Nava without a case, the Crash stopped working.
I only hear a slight audio click when it gets triggered but no real sound.
So I finally got time to take my scope for a spin and started looking into it. Since the HH/cymbals are sample-based rather than pure analog, I'm having a hard time knowing where to look.. I measured the "trig" and "acc" spots on the PCB and got the following results :
Accent
Trigger
Those seem to be fine. Then I looked at the schematics and wanted to know if IC63 was getting a signal from IC59 pin 3 so I measured that pin and that's what I get, the signal is very weak, only a few mV (is that good or bad? don't ask me!)
Remember guys, I have no idea what I'm doing
. What would you guys advise I measure to troubleshoot the crash? I'm a novice in electronics.
Accent
Trigger
