Good question. But isn't this show the original 909 works? I never had one, so I don't know...3thernet wrote:Will it ever be possible to enter notes in step mode without having to "save" them to the sequence via the enter button?
Nava2021 (post v1.028beta)
Nope! With the original 909 you never needed to save your patterns to the EPROM, it was all automatic. Though, you weren't able to link sequences once a sequence was already running... a major benefit of the NAVA. However, on the original 909 you could edit the multiple 'pages' of sequences without needing to hit the enter button once notes were entered!FlavioB wrote:G
Ok thanks for clarifying.
But then: why the save button was added to the Nava? I had my time getting used to it (like on the Beatstep Pro)!!!
I think Vincent decided to use a Save button because the TR909 uses static RAM to store patterns while the Nava uses an EEPROM to store patterns. EEPROM has a limit to the amount of times it can be rewritten.
So to reduce wear on the EEPROM you need to tell the Nava to save patterns.
I hope this answers any questions about dropping the save button.
Greetz,
Neuro
Greetz,
Neuro
Thanks Neuro - that explains it quite good!
F.
F.
Oh wow! Didn't see external pattern change was already included in the firmware! Great news. Thanks for your reply.Neuromancer wrote: Thanks, I don't see a way of bricking the machine when updating. Nothing fancy is being done at that moment.
Change pattern is implemented using midi notes. See the wiki or release notes.
https://github.com/BenZonneveld/Nava-20 ... /wiki/MIDI
My current priority is implementing pattern groups in step or tap mode.
Neuromancer
Thanks again
As I just changed my audio interface setup I'm not sure if it's the Nava or the interfaces/Asio/Cubase messing things up but....
When using the Nava as a MIDI Slave my sounds seem to be played ahead of the beat making it impossible to get the Nava in sync with myother parts running from Cubase.
EDIT: The latency problems where caused by Cubase/Asio, not the Nava.
Also, first time in 7 months I made a track.
Neuromancer wrote: Also, first time in 7 months I made a track.
Let's hear this track then!Neuromancer wrote: Also, first time in 7 months I made a track.
Here it is.FlavioB wrote:Let's hear this track then!Neuromancer wrote: Also, first time in 7 months I made a track.
2 Parts of 303
several parts of Prophet X and Prophet 12
and my Nava.
Greetz,
Neuromancer
