Noise section trimmer voltage?
  • That said, I'm still not getting a correct voltage at the noise trimmer pot, after going through and checking all resistor values with a meter, and double checking all the capacitors are correct. +15/+5/-5 voltages have been fine all the way through, bassdrum finished last night.
    Sorry, but you wrote +15/+5/-5 ? Correct is +15/-15/+5V
    and just to be sure...the 130mV in AC on your meter
  • This is how I organized my build:
    I labeled one page per section ("HiHats" in the photo) and taped the number of each component to each page in the order shown in the build instructions. When I work on a section, there are no little baggies to search through; it's all on the page. Static-sensitive ICs and transistors I keep separate until needed.
    Viewed 11377 times
  • The measurement of the AC voltage isn't exactly by me.
    My cheap 4 digit shows 130mV,
    A expensiv and calibrated 6 digits DMM Shows 250mV but in AC mode it changes every second to a other value near 250mV.
    A new digital Oscilloscope shows arround 150mV.
    Have inserted a 68k resistor to have enough space for the trimpot.
  • effegee wrote:This is how I organized my build:
    Good idea - saves buying a load of little bags :)
    Ah yes 15, -15 and 5v...
  • Measurement Info for 130mV
    from the Roland Servicemanual is the 130mV RMS (with measurement technology in 1981)
    its a noise waveform, the peaks are different.
    its a difference in measurement between TRUE-RMS, RMS and cheap DMM without RMS..
    RMS is only exact on SINUS signals
    TRUE RMS are better as RMS and handle all signal forms - but its a mathematical function and you have to respect this tolerances.
    from my POV: the best choice is a oscilloscope and for doublecheck a TRUE RMS multimeter
    here you find a graphic from AC RMS measurements with different DMM:
    http://www.radiomuseum.org/forum/die_me ... e_rms.html
  • Patrick wrote:Measurement Info for 130mV
    I have a question and please excuse my ignorance in these matters if it proves to be a bit dumb. ;)
    My Multimeter cannot show AC Millivolts, so can I safely use a software Oscilloscope on my computer? The input would be via the soundcard.
    Your soundcard oscilloscope must have a calibration /specially voltage regulation.
    Or you must feed a 1v signal to get a voltagebaseline on your pc.
    A analog oscilloscope cost arround 50€ on ebay and its a must have for troubleshooting
  • Just another question for clarification, as I am also measuring approximately 260mV at least (and I am absolutely sure that I did not pick the wrong parts (R127 is 4.7k for now):
    Is it really correct to change R127 already now to 47k, at this point, even if the Noise part is the only part finished so far (besides the Power Supply of course)? Wouldn't the value measured change under load (i.e. if the rest of circuits are finished)? In that case I would continue building the rest first and check again at the end. But if I am getting this wrong and the value does not change under load, it would make sense to change the value now.
    When did you guys change your R127? Right at the point you measured for the first time or after everything was built?
    How should I proceed?
    Cheers,
    jmx.
