- Posts 266
Neuromancer wrote:I added MIDI out of a playing pattern in the 1.017 sources, took me about 1 hour to do this.
But as there are many bugfixes in more recent firmware I would like to have the sources.
I'd love to be able to help, as I'd also like to get bugs fixed and features added/improved - but sadly I'm no coder
I know of some users (rv0 at least) who got involved in the code... maybe asking them would be a start?
- Posts 64
With the current available source code (1.017) it feels like re-implementing bugfixes for bugs that are solved in later firmware releases.
- Posts 266
Neuromancer wrote:With the current available source code (1.017) it feels like re-implementing bugfixes for bugs that are solved in later firmware releases.
Indeed...
Did you try getting in touch with the guys who updated the code already? I mean the code on GitHub...
- Posts 64
Sad to see such a nice product with orphaned support on the firmware.
I have decided to rewrite the firmware for myself as my Nava is a bit different.
The source code will be available at
https://github.com/BenZonneveld/Nava-909-Firmware
At the moment I can't test all functions as my Nava isn't finished, only the sequencer part is up and running. Waiting for parts and money to buy those parts.
- Posts 266
Neuromancer wrote:Sad to see such a nice product with orphaned support on the firmware.
Very sad indeed! :-/
In what terms is it different?
F.
- Posts 64
PM to you explaining this
- Posts 9
zabox wrote:Mh, on some occasions i could get it to jump one 1/16 note, but not to a slight offset as you describe it. But i noticed that the shuffle is completely off, only half as strong as it should be and in slave mode there‘s only one working shuffle variation (0-4 off, 5-7 on).
I‘m sorry that i didn‘t notice this earlier, but i‘m going to rewrite the shuffle function and match it to a real 909
It may however take a few weeks. If anyone needs an earlier fix for some reason, i can ask vincent to upload a quick and dirty patch that i‘m already running on my nava. (But right now it only works in the regular 16th note scale).
Hi , i would like to know of 1.28 beta firmware fixed the swing problem in slave mode. Thanxx
- Posts 1
Hmm ok...
I have no idea what that is/was related to but it could well have something to do with "total accent".
In my case my OH decay was dependend on the CH decay.
When CH decal was fully counterclockwise the OH was also very short.
When I turned the CH decay pot in clockwise direction the OH also got longer.
The OH decay pot however had no effect on the actual OH decay.
I could try updating to 1.09 again and see what happens. Maybe something went wrong in my initial update to 1.09.
The only thing I can say is that everything was back to normal after I installed 1.07 again.
I did this together with LED-Man so he can confirm that and we also compared our NAVAs.
He never installed 1.09 and his was fine with 1.07.
+ decoder303 also seems to have run into this issue.
We'll see what Vincent finds out.
- Posts 77
Setting up your Vizio device is simple with
vizio.com/setup. Whether you’re installing a smart TV, soundbar, or streaming device, this step-by-step guide ensures a hassle-free process. By visiting
vizio.com/setup, you can register your product, download essential apps, and activate streaming services. The portal at
vizio.com/setup also provides troubleshooting tips and software updates to optimize performance. Users often rely on
vizio.com/setup to quickly complete installation without technical issues. From connecting Wi-Fi to customizing settings, everything is streamlined. Make your entertainment experience better by using vizio.com/setup for smooth configuration and access to the latest Vizio features.
