Pistrix,
Replace the value "0x0F" on the last line of the Nava_v_1_020_All.bat file by "0x3F"
Save the file and try again to burn your chip
firmware update problem 1.017 -> 1.0xx
[EDIT]I wrote different ArduinoISP code, it is revised.
hello,
I have tried instruction by e-licktronic.
however, it has been still 1.017.
at first, I tried with windows pc which I borrowed, but error occur following.
I tried uninstall and re-install ArduinoIDE and driver, but these can not help it.
so I tried with Mac OSX.
writer is arduino duemilanove with Arduino ISP and IDE v1.8.0.
I wrote Arduino ISP to arduino duemilanove, and connected with nava.
commands are following.
first, protocol error occurs
I found solution.
https://github.com/arduino/Arduino/issues/730
I modified Arduino ISP and wrote again.
next, I tried to execute avrdude command, there were problem verifying lock bit like pistrix case.
I modified command value of bit "0x3F" to "0x0F", it look like success.
then I executed commands efuse, hfuse and lfuse, these were success.
next, I tried execute writing Nava_v1_020.hex to flash. however, verifying error occurred.
and following log with add more verbose.
https://www.dropbox.com/s/0ohfp9t6qa7ev ... se.log.txt
additional, I notice that Error LED lighted up while executing command.
Should I tried Arduino UNO not duemilanove?
please help or further instruction.
Thank you.
hello,
Code: Select all
avrdude: ser_open(): can't set com-state for "\\.\COM4"
Code: Select all
/usr/local/bin/avrdude -P /dev/cu.usbserial-A900abz5 -C ~/nava/tool/bin/avrdude.conf -c avrisp -p m1284p -b 19200 -u -e -U lock:w:0x3F:m -v
/usr/local/bin/avrdude -P /dev/cu.usbserial-A900abz5 -C ~/nava/tool/bin/avrdude.conf -c avrisp -p m1284p -b 19200 -u -U efuse:w:0xFD:m -v
/usr/local/bin/avrdude -P /dev/cu.usbserial-A900abz5 -C ~/nava/tool/bin/avrdude.conf -c avrisp -p m1284p -b 19200 -u -U hfuse:w:0xDC:m -v
/usr/local/bin/avrdude -P /dev/cu.usbserial-A900abz5 -C ~/nava/tool/bin/avrdude.conf -c avrisp -p m1284p -b 19200 -u -U lfuse:w:0xD6:m -v
/usr/local/bin/avrdude -P /dev/cu.usbserial-A900abz5 -C ~/nava/tool/bin/avrdude.conf -c avrisp -p m1284p -b 19200 -U flash:w:~/nava/tool/Nava_v1_020.hex:i -v
/usr/local/bin/avrdude -P /dev/cu.usbserial-A900abz5 -C ~/nava/tool/bin/avrdude.conf -c avrisp -p m1284p -b 19200 -U flash:w:~/nava/tool/BootNava.hex:i -v -D
/usr/local/bin/avrdude -P /dev/cu.usbserial-A900abz5 -C ~/nava/tool/bin/avrdude.conf -c avrisp -p m1284p -b 19200 -U lock:w:0x0F:m -v
Code: Select all
avrdude: Version 6.3, compiled on Mar 15 2016 at 21:26:45
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "~/nava/tool/bin/avrdude.conf"
User configuration file is "/Users/junk16/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbserial-A900abz5
Using Programmer : avrisp
Overriding Baud Rate : 19200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x15
AVR Part : ATmega1284P
Chip Erase delay : 55000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 128 0 no 4096 8 0 9000 9000 0xff 0xff
flash 65 10 256 0 yes 131072 256 512 4500 4500 0xff 0xff
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel AVR ISP
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x14
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x02
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x10
Hardware Version: 32767
Firmware Version: 1.214220458
Topcard : STK502
Vtarget : 1.8 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: stk500_initialize(): (b) protocol error, expect=0x10, resp=0x01
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x10
avrdude done. Thank you.https://github.com/arduino/Arduino/issues/730
Code: Select all
// ArduinoISP
// Copyright (c) 2008-2011 Randall Bohn
// If you require a license, see
// http://www.opensource.org/licenses/bsd-license.php
// This sketch turns the Arduino into a AVRISP
// using the following arduino pins:
// Pin 10 is used to reset the target microcontroller.
// By default, the hardware SPI pins MISO, MOSI and SCK pins are used
// to communicate with the target. On all Arduinos, these pins can be found
// on the ICSP/SPI header:
// MISO °. . 5V (!) Avoid this pin on Due, Zero...
// SCK . . MOSI
// . . GND
// On some Arduinos (Uno,...), pins MOSI, MISO and SCK are the same pins
// as digital pin 11, 12 and 13, respectively. That is why many tutorials
// instruct you to hook up the target to these pins. If you find this wiring
// more practical, have a define USE_OLD_STYLE_WIRING. This will work even
// even when not using an Uno. (On an Uno this is not needed).
// Alternatively you can use any other digital pin by configuring software ('BitBanged')
// SPI and having appropriate defines for PIN_MOSI, PIN_MISO and PIN_SCK.
// IMPORTANT: When using an Arduino that is not 5V tolerant (Due, Zero, ...)
// as the programmer, make sure to not expose any of the programmer's pins to 5V.
// A simple way to accomplish this is to power the complete system (programmer
// and target) at 3V3.
// Put an LED (with resistor) on the following pins:
// 9: Heartbeat - shows the programmer is running
// 8: Error - Lights up if something goes wrong (use red if that makes sense)
// 7: Programming - In communication with the slave
#include "Arduino.h"
#undef SERIAL
#define PROG_FLICKER true
// Configure SPI clock (in Hz).
// E.g. for an attiny @128 kHz: the datasheet states that both the high
// and low spi clock pulse must be > 2 cpu cycles, so take 3 cycles i.e.
// divide target f_cpu by 6:
// #define SPI_CLOCK (128000/6)
// A clock slow enough for an attiny85 @ 1MHz, is a reasonable default:
#define SPI_CLOCK (1000000/6)
// Select hardware or software SPI, depending on SPI clock.
// Currently only for AVR, for other archs (Due, Zero,...),
// hardware SPI is probably too fast anyway.
#if defined(ARDUINO_ARCH_AVR)
#if SPI_CLOCK > (F_CPU / 128)
#define USE_HARDWARE_SPI
#endif
#endif
// Configure which pins to use:
// The standard pin configuration.
#ifndef ARDUINO_HOODLOADER2
#define RESET 10 // Use pin 10 to reset the target rather than SS
#define LED_HB 9
#define LED_ERR 8
#define LED_PMODE 7
// Uncomment following line to use the old Uno style wiring
// (using pin 11, 12 and 13 instead of the SPI header) on Leonardo, Due...
//#define USE_OLD_STYLE_WIRING
#ifdef USE_OLD_STYLE_WIRING
#define PIN_MOSI 11
#define PIN_MISO 12
#define PIN_SCK 13
#endif
// HOODLOADER2 means running sketches on the atmega16u2
// serial converter chips on Uno or Mega boards.
// We must use pins that are broken out:
#else
#define RESET 4
#define LED_HB 7
#define LED_ERR 6
#define LED_PMODE 5
#endif
// By default, use hardware SPI pins:
#ifndef PIN_MOSI
#define PIN_MOSI MOSI
#endif
#ifndef PIN_MISO
#define PIN_MISO MISO
#endif
#ifndef PIN_SCK
#define PIN_SCK SCK
#endif
// Force bitbanged SPI if not using the hardware SPI pins:
#if (PIN_MISO != MISO) || (PIN_MOSI != MOSI) || (PIN_SCK != SCK)
#undef USE_HARDWARE_SPI
#endif
// Configure the serial port to use.
// Prefer the USB virtual serial port (aka. native USB port), if the Arduino has one:
// - it does not autoreset (except for the magic baud rate of 1200).
// - it is more reliable because of USB handshaking.
// Leonardo and similar have an USB virtual serial port: 'Serial'.
// Due and Zero have an USB virtual serial port: 'SerialUSB'.
// On the Due and Zero, 'Serial' can be used too, provided you disable autoreset.
// To use 'Serial': #define SERIAL Serial
#ifdef SERIAL_PORT_USBVIRTUAL
#define SERIAL SERIAL_PORT_USBVIRTUAL
#else
#endif
// Configure the baud rate:
#define BAUDRATE 19200
// #define BAUDRATE 115200
// #define BAUDRATE 1000000
#define HWVER 2
#define SWMAJ 1
#define SWMIN 18
// STK Definitions
#define STK_OK 0x10
#define STK_FAILED 0x11
#define STK_UNKNOWN 0x12
#define STK_INSYNC 0x14
#define STK_NOSYNC 0x15
#define CRC_EOP 0x20 //ok it is a space...
void pulse(int pin, int times);
#ifdef USE_HARDWARE_SPI
#include "SPI.h"
#else
#define SPI_MODE0 0x00
class SPISettings {
public:
// clock is in Hz
SPISettings(uint32_t clock, uint8_t bitOrder, uint8_t dataMode) : clock(clock){
(void) bitOrder;
(void) dataMode;
private:
uint32_t clock;
friend class BitBangedSPI;
class BitBangedSPI {
public:
void begin() {
digitalWrite(PIN_SCK, LOW);
digitalWrite(PIN_MOSI, LOW);
pinMode(PIN_SCK, OUTPUT);
pinMode(PIN_MOSI, OUTPUT);
pinMode(PIN_MISO, INPUT);
void beginTransaction(SPISettings settings) {
pulseWidth = (500000 + settings.clock - 1) / settings.clock;
if (pulseWidth == 0)
pulseWidth = 1;
void end() {}
uint8_t transfer (uint8_t b) {
for (unsigned int i = 0; i < 8; ++i) {
digitalWrite(PIN_MOSI, (b & 0x80) ? HIGH : LOW);
digitalWrite(PIN_SCK, HIGH);
delayMicroseconds(pulseWidth);
b = (b << 1) | digitalRead(PIN_MISO);
digitalWrite(PIN_SCK, LOW); // slow pulse
return b;
private:
unsigned long pulseWidth; // in microseconds
static BitBangedSPI SPI;
#endif
void setup() {
SERIAL.begin(BAUDRATE);
pinMode(LED_PMODE, OUTPUT);
pulse(LED_PMODE, 2);
pinMode(LED_ERR, OUTPUT);
pulse(LED_ERR, 2);
pinMode(LED_HB, OUTPUT);
pulse(LED_HB, 2);
int initSent=0;
int error = 0;
int pmode = 0;
// address for reading and writing, set by 'U' command
unsigned int here;
uint8_t buff[256]; // global block storage
#define beget16(addr) (*addr * 256 + *(addr+1) )
typedef struct param {
uint8_t devicecode;
uint8_t revision;
uint8_t progtype;
uint8_t parmode;
uint8_t polling;
uint8_t selftimed;
uint8_t lockbytes;
uint8_t fusebytes;
uint8_t flashpoll;
uint16_t eeprompoll;
uint16_t pagesize;
uint16_t eepromsize;
uint32_t flashsize;
parameter;
parameter param;
// this provides a heartbeat on pin 9, so you can tell the software is running.
uint8_t hbval = 128;
int8_t hbdelta = 8;
void heartbeat() {
static unsigned long last_time = 0;
unsigned long now = millis();
if ((now - last_time) < 40)
return;
last_time = now;
if (hbval > 192) hbdelta = -hbdelta;
if (hbval < 32) hbdelta = -hbdelta;
hbval += hbdelta;
analogWrite(LED_HB, hbval);
static bool rst_active_high;
void reset_target(bool reset) {
digitalWrite(RESET, ((reset && rst_active_high) || (!reset && !rst_active_high)) ? HIGH : LOW);
void loop(void) {
// is pmode active?
if (pmode) {
digitalWrite(LED_PMODE, HIGH);
} else {
digitalWrite(LED_PMODE, LOW);
// is there an error?
if (error) {
digitalWrite(LED_ERR, HIGH);
} else {
digitalWrite(LED_ERR, LOW);
// light the heartbeat LED
heartbeat();
if (SERIAL.available()) {
avrisp();
uint8_t getch() {
while (!SERIAL.available());
return SERIAL.read();
void fill(int n) {
for (int x = 0; x < n; x++) {
buff[x] = getch();
#define PTIME 30
void pulse(int pin, int times) {
do {
digitalWrite(pin, HIGH);
delay(PTIME);
digitalWrite(pin, LOW);
delay(PTIME);
} while (times--);
void prog_lamp(int state) {
if (PROG_FLICKER) {
digitalWrite(LED_PMODE, state);
uint8_t spi_transaction(uint8_t a, uint8_t b, uint8_t c, uint8_t d) {
SPI.transfer(a);
SPI.transfer(b);
SPI.transfer(c);
return SPI.transfer(d);
void empty_reply() {
if (CRC_EOP == getch()) {
SERIAL.print((char)STK_INSYNC);
SERIAL.print((char)STK_OK);
} else {
error++;
SERIAL.print((char)STK_NOSYNC);
void breply(uint8_t b) {
SERIAL.print((char)b);
} else {
error++;
void get_version(uint8_t c) {
switch (c) {
case 0x80:
breply(HWVER);
break;
case 0x81:
breply(SWMAJ);
break;
case 0x82:
breply(SWMIN);
break;
case 0x93:
breply('S'); // serial programmer
break;
default:
breply(0);
void set_parameters() {
// call this after reading paramter packet into buff[]
param.devicecode = buff[0];
param.revision = buff[1];
param.progtype = buff[2];
param.parmode = buff[3];
param.polling = buff[4];
param.selftimed = buff[5];
param.lockbytes = buff[6];
param.fusebytes = buff[7];
param.flashpoll = buff[8];
// ignore buff[9] (= buff[8])
// following are 16 bits (big endian)
param.eeprompoll = beget16(&buff[10]);
param.pagesize = beget16(&buff[12]);
param.eepromsize = beget16(&buff[14]);
// 32 bits flashsize (big endian)
param.flashsize = buff[16] * 0x01000000
+ buff[17] * 0x00010000
+ buff[18] * 0x00000100
+ buff[19];
// avr devices have active low reset, at89sx are active high
rst_active_high = (param.devicecode >= 0xe0);
void start_pmode() {
// Reset target before driving PIN_SCK or PIN_MOSI
// SPI.begin() will configure SS as output,
// so SPI master mode is selected.
// We have defined RESET as pin 10,
// which for many arduino's is not the SS pin.
// So we have to configure RESET as output here,
// (reset_target() first sets the correct level)
reset_target(true);
pinMode(RESET, OUTPUT);
SPI.begin();
SPI.beginTransaction(SPISettings(SPI_CLOCK, MSBFIRST, SPI_MODE0));
// See avr datasheets, chapter "SERIAL_PRG Programming Algorithm":
// Pulse RESET after PIN_SCK is low:
delay(20); // discharge PIN_SCK, value arbitrally chosen
reset_target(false);
// Pulse must be minimum 2 target CPU clock cycles
// so 100 usec is ok for CPU speeds above 20KHz
delayMicroseconds(100);
reset_target(true);
// Send the enable programming command:
delay(50); // datasheet: must be > 20 msec
spi_transaction(0xAC, 0x53, 0x00, 0x00);
pmode = 1;
void end_pmode() {
SPI.end();
// We're about to take the target out of reset
// so configure SPI pins as input
pinMode(PIN_MOSI, INPUT);
pinMode(PIN_SCK, INPUT);
pinMode(RESET, INPUT);
pmode = 0;
void universal() {
uint8_t ch;
fill(4);
ch = spi_transaction(buff[0], buff[1], buff[2], buff[3]);
breply(ch);
void flash(uint8_t hilo, unsigned int addr, uint8_t data) {
spi_transaction(0x40 + 8 * hilo,
addr >> 8 & 0xFF,
addr & 0xFF,
data);
void commit(unsigned int addr) {
if (PROG_FLICKER) {
prog_lamp(LOW);
spi_transaction(0x4C, (addr >> 8) & 0xFF, addr & 0xFF, 0);
if (PROG_FLICKER) {
delay(PTIME);
prog_lamp(HIGH);
unsigned int current_page() {
if (param.pagesize == 32) {
return here & 0xFFFFFFF0;
if (param.pagesize == 64) {
return here & 0xFFFFFFE0;
if (param.pagesize == 128) {
return here & 0xFFFFFFC0;
if (param.pagesize == 256) {
return here & 0xFFFFFF80;
return here;
void write_flash(int length) {
fill(length);
SERIAL.print((char) STK_INSYNC);
SERIAL.print((char) write_flash_pages(length));
} else {
error++;
SERIAL.print((char) STK_NOSYNC);
uint8_t write_flash_pages(int length) {
int x = 0;
unsigned int page = current_page();
while (x < length) {
if (page != current_page()) {
commit(page);
flash(LOW, here, buff[x++]);
flash(HIGH, here, buff[x++]);
here++;
commit(page);
return STK_OK;
#define EECHUNK (32)
uint8_t write_eeprom(unsigned int length) {
// here is a word address, get the byte address
unsigned int start = here * 2;
unsigned int remaining = length;
if (length > param.eepromsize) {
error++;
return STK_FAILED;
while (remaining > EECHUNK) {
write_eeprom_chunk(start, EECHUNK);
start += EECHUNK;
remaining -= EECHUNK;
write_eeprom_chunk(start, remaining);
return STK_OK;
// write (length) bytes, (start) is a byte address
uint8_t write_eeprom_chunk(unsigned int start, unsigned int length) {
// this writes byte-by-byte,
// page writing may be faster (4 bytes at a time)
fill(length);
prog_lamp(LOW);
for (unsigned int x = 0; x < length; x++) {
unsigned int addr = start + x;
spi_transaction(0xC0, (addr >> 8) & 0xFF, addr & 0xFF, buff[x]);
delay(45);
prog_lamp(HIGH);
return STK_OK;
void program_page() {
char result = (char) STK_FAILED;
unsigned int length = 256 * getch();
length += getch();
char memtype = getch();
// flash memory @here, (length) bytes
if (memtype == 'F') {
write_flash(length);
return;
if (memtype == 'E') {
result = (char)write_eeprom(length);
SERIAL.print(result);
} else {
error++;
return;
SERIAL.print((char)STK_FAILED);
return;
uint8_t flash_read(uint8_t hilo, unsigned int addr) {
return spi_transaction(0x20 + hilo * 8,
(addr >> 8) & 0xFF,
addr & 0xFF,
0);
char flash_read_page(int length) {
for (int x = 0; x < length; x += 2) {
uint8_t low = flash_read(LOW, here);
SERIAL.print((char) low);
uint8_t high = flash_read(HIGH, here);
SERIAL.print((char) high);
here++;
return STK_OK;
char eeprom_read_page(int length) {
// here again we have a word address
for (int x = 0; x < length; x++) {
uint8_t ee = spi_transaction(0xA0, (addr >> 8) & 0xFF, addr & 0xFF, 0xFF);
SERIAL.print((char) ee);
return STK_OK;
void read_page() {
char result = (char)STK_FAILED;
length += getch();
if (CRC_EOP != getch()) {
error++;
return;
if (memtype == 'F') result = flash_read_page(length);
if (memtype == 'E') result = eeprom_read_page(length);
void read_signature() {
error++;
return;
uint8_t high = spi_transaction(0x30, 0x00, 0x00, 0x00);
uint8_t middle = spi_transaction(0x30, 0x00, 0x01, 0x00);
SERIAL.print((char) middle);
uint8_t low = spi_transaction(0x30, 0x00, 0x02, 0x00);
SERIAL.print((char) STK_OK);
void avrisp() {
uint8_t ch = getch();
switch (ch) {
case '0': // signon
error = 0;
if(! initSent) empty_reply();
initSent = 1;
break;
case '1':
if (getch() == CRC_EOP) {
SERIAL.print("AVR ISP");
else {
error++;
break;
case 'A':
get_version(getch());
break;
case 'B':
fill(20);
set_parameters();
empty_reply();
break;
case 'E': // extended parameters - ignore for now
fill(5);
empty_reply();
break;
case 'P':
if (!pmode)
start_pmode();
empty_reply();
break;
case 'U': // set address (word)
here = getch();
here += 256 * getch();
empty_reply();
break;
case 0x60: //STK_PROG_FLASH
getch(); // low addr
getch(); // high addr
empty_reply();
break;
case 0x61: //STK_PROG_DATA
getch(); // data
empty_reply();
break;
case 0x64: //STK_PROG_PAGE
program_page();
break;
case 0x74: //STK_READ_PAGE 't'
read_page();
break;
case 'V': //0x56
universal();
break;
case 'Q': //0x51
error = 0;
end_pmode();
empty_reply();
break;
case 0x75: //STK_READ_SIGN 'u'
read_signature();
break;
// expecting a command, not CRC_EOP
// this is how we can get back in sync
case CRC_EOP:
error++;
break;
// anything else we will return STK_UNKNOWN
default:
error++;
SERIAL.print((char)STK_UNKNOWN);
else
Code: Select all
PAGEL : PD7
BS2 : PA0
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x15
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.04s
avrdude: Device signature = 0x1e9705 (probably m1284p)
avrdude: erasing chip
avrdude: reading input file "0x3F"
avrdude: writing lock (1 bytes):
Writing | | 0% 0.00s ***failed;
Writing | ################################################## | 100% 0.13s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x3F:
avrdude: load data lock data from input file 0x3F:
avrdude: input file 0x3F contains 1 bytes
avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.02s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
0x0f != 0x3f
avrdude: verification error; content mismatch
Code: Select all
PAGEL : PD7
BS2 : PA0
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
Reading | ################################################## | 100% 0.05s
avrdude: reading input file "0x0F"
Writing | ################################################## | 100% 0.01s
avrdude: verifying lock memory against 0x0F:
avrdude: load data lock data from input file 0x0F:
avrdude: input file 0x0F contains 1 bytes
Reading | ################################################## | 100% 0.01s
avrdude: 1 bytes of lock verified
Code: Select all
PAGEL : PD7
BS2 : PA0
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: safemode: hfuse reads as DC
avrdude: safemode: efuse reads as FD
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: reading input file "~/nava/tool/Nava_v1_020.hex"
avrdude: writing flash (39292 bytes):
Writing | ################################################## | 100% 39.40s
avrdude: 39292 bytes of flash written
avrdude: verifying flash memory against ~/nava/tool/Nava_v1_020.hex:
avrdude: load data flash data from input file ~/nava/tool/Nava_v1_020.hex:
avrdude: input file ~/nava/tool/Nava_v1_020.hex contains 39292 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 24.62s
avrdude: verification error, first mismatch at byte 0x0002
0xf2 != 0xf8
avrdude: safemode: Fuses OK (E:FD, H:DC, L:D6)
Thank you.
Junk16,
Try to replace "avrIsp" programmer name in the bat file by "arduino".
I tried to replace programmer 'arduino'.
but it is same result like before programmer avrIsp.
following is execution log.
adding more verbose log.
https://drive.google.com/file/d/0ByZNlu ... sp=sharing.
thank you.
Code: Select all
/usr/local/bin/avrdude -P /dev/cu.usbserial-A900abz5 -C ~/nava/tool/bin/avrdude.conf -c arduino -p m1284p -b 19200 -U flash:w:~/nava/tool/Nava_v1_020.hex:i -v
Code: Select all
Using Programmer : arduino
PAGEL : PD7
BS2 : PA0
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Programmer Type : Arduino
Description : Arduino
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: reading input file "~/nava/tool/bin/Nava_v1_020.hex"
Writing | ################################################## | 100% 39.39s
avrdude: verifying flash memory against ~/nava/tool/bin/Nava_v1_020.hex:
avrdude: load data flash data from input file ~/nava/tool/bin/Nava_v1_020.hex:
avrdude: input file ~/nava/tool/bin/Nava_v1_020.hex contains 39292 bytes
0xf2 != 0xf8
thank you.
That results in the last line failing verification just as the first line does.e-licktronic wrote:Pistrix,
But if I change the "0x3F" in the first line to "0x0F" it passes verification.
However the "Nava_v1_020.hex" file still fails verification:
Just looked at his code quotations, It seems junk16 and I are getting identical results..avrdude.exe: verification error, first mismatch at byte 0x0002
0xf2 != 0xf8
avrdude.exe: verification error; content mismatch
Pistrix,
On the Nava ICSP connector "MISO" and "MOSI" are reversed.
You should switch this two pins.
Try it and let me know
/usr/local/bin/avrdude -P /dev/cu.usbserial-A900abz5 -C ./bin/avrdude.conf -c avrisp -p m1284p -b 19200 -u -e -U lock:w:0x0F:m -v
/usr/local/bin/avrdude -P /dev/cu.usbserial-A900abz5 -C ./bin/avrdude.conf -c avrisp -p m1284p -b 19200 -U flash:w:./Nava_v1_020.hex:i -v
regard
I have tried, and signature error occurred.On the Nava ICSP connector "MISO" and "MOSI" are reversed.
Code: Select all
System wide configuration file is "./bin/avrdude.conf"
PAGEL : PD7
BS2 : PA0
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: Device signature = 0xffffff (probably .reduced_core_tiny) (retrying)
avrdude: Device signature = 0xff0000
avrdude: Expected signature for ATmega1284P is 1E 97 05
Double check chip, or use -F to override this check.
Code: Select all
PAGEL : PD7
BS2 : PA0
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: Yikes! Invalid device signature.
this check.
Yes, I noticed the NAVA ICSP pins. I tried it both ways. When the MISO/MOSI pins are switched, avrdude gives critical errors (same results as junk16).e-licktronic wrote:Pistrix,
pistrix, junk16,
Do you have an other *.HEX file to burn on your Atmega1284p ?
To know if the problem come from the program, the chip or your IDE burner.
It does seem to successfully burn and verify the "BootNava.hex" step of the process, but I suppose that's a different part of the chip's memory.
I noticed that the Arduino site says to add a 10uf capacitor between reset and ground on the Arduino Uno (as well as the Duemilanove) when using it with ArduinoISP. I hadn't done this before, but have added it now. It didn't change my results though.
I tried to burn the Yocto 2.0 firmware instead of the Nava firmware. It doesn't succeed either, with similar results.
Code: Select all
avrdude.exe: input file c:\tools\Yocto_2_0.hex contains 26976 bytes
avrdude.exe: reading on-chip flash data:
Reading | ################################################## | 100% 18.99s
avrdude.exe: verifying ...
0xf2 != 0x89
