Has anyone looked into the tantalum caps in the original which are substituted in the nava?
They are used mostly in sound envelope and the decay circuits, and noted on the TR-909 schematics with a Circle with a T inside.
Just wanted others opinions on sticking with OG style parts or compatible with the builds.
				Nava v1.0 BOM [5/18/16 IMPORTANT BOM UPDATE]
Just going through my build now and noticed the current mouser BOM has two versions of the .1uF film capacitors:
80-R82DC3100AA50J
80-R82EC3100AA70J
They're both the same price, one rated to 100v and the other to 63v so either one should be fine. Just a note for anyone buying the project cart that you should remove one.
				80-R82DC3100AA50J
80-R82EC3100AA70J
These LED standoffs work better than the current ones in the BOM:
Mouser Part #: 534-7364
http://www.mouser.com/ProductDetail/Key ... 0gMA%3D%3D
can anyone enlighten me about what the deal is with this part:
http://www.mouser.de/Search/ProductDeta ... 94-SFR25-0
"Metal Film Resistors - Through Hole 400mW 0 Ohm Jumper SFR55 Historical p/n"
why do I need to buy a 0 Ohm jumper? can't I just use the leads of the resistors already built in?
Mouser needs your Money
Drop this Position from your Mouser basket
But they're pretty, they're turquoise...
				beeb wrote:But they're pretty, they're turquoise...
Is this all that's needed Vincent? I have been holding off until the full list of additions is needed......e-licktronic wrote:
EDIT 8/15/16
-Nava Mouser BOM updated
-Red backlight 16x2 LCD OUT OF STOCK (can find on Ebay)
-390pF Polystyren capacitor OUTOF STOCK (available by Musikding or BanzaiMusic)
EDIT 6/8/16
-MF1/4LCT52R105J Koa Speer 1M resistor replace by MF1/4LCT52R105G
EDIT 5/23/16
-Add Kemet R82EC3100AA70J 0.1uF capacitor 7pcs
-1Kohm resistor quantity updated to 29pcs
-1K2ohm resistor quantity updated to 41pcs
-20Kohm resistor quantity updated to 5pcs
-FCI 68000-416HLF 16 pins male pin header added to the BOM
EDIT 5/21/16
-20Kohm resistor quantity updated to 5 pcs
-68Kohm resistor quantity updated to 4 pcs
-100kohm CFR-25JR-52-100K Yageo resistors replace by 291-100K-RC Xicon
EDIT 5/20/16
-100pF capacitor quantity updated to 5 pcs
EDIT 5/18/16
Important update! On semiconductor EEprom does not seems to work with current firmware so you need the Microchip one
-On semiconductor CAT24M01 EEprom replace by Micropchip 24LC1025
EDIT 5/17/16
-Nichicon 0.028uF cap QYX1H273KTP replace by Panasonic ECQ-E2273KF3
EDIT 5/3/16
Nava v1.0 Mouser Bom updated
I'm about to order more from mouser and wanted to check first.............
Is it possible for you to update all these additions with the amount needed?
i've just finished my nava, and i've found 3 problems with the bom :
- 1,2kohm resistor accordind to the documentation, we need 42 (41 for the sequencer and 1 for the I/O board).
- C163 film capacitor 0,47uF not listed in the BOM.
- and 0,1uF film resistor we have 14 (7 in 63V and 7 in 100V) but according to the documentation we need only 8.
Hope this help.
Hope this help.
that helps, i'm about to order the bom, thanx!
