I'm thinking about second batch so if there is someone interested in it please write me: kacperpawluk@gmail.com.
When i collect enough interested people then I will start ordering.
PS. For all people who wrote me about buying enclosures within production time - please write me again if you're still interested in it.
				Yocto Metal Box EU - Group Buy
Hi there, I might be interested. Not sure how much would it cost me within the shipment I'm in France.
Also I've made myself a design here:
https://www.dropbox.com/s/8hjjggcnzeput ... 0.pdf?dl=0
It has been made with the official vectorial Design from E-Licktronic so it should fit perfectly withe PCBs. It's free to use/modify and such. One thing I really like on my design panel is the name of each instrument under the step button. It makes sens when you 're using the mute/ solo function. The colors can be rethink though. The original 808 is not black black it is more vanished/faded black or a really really dark grey. it gives the 80's touch in my own opinion. A deep real black makes the machine more modern I guess.
I think the design have been made a couple of years now (I was on the first batch ever ordered). So today I can see what's wrong here and there. Like the typo or some colors.
Anyway! Who like it? I don't mind if it's not used if only at least someone can put those instruments names beneath the the step buttons on the selected design for the mute/solo function!
Cheers!
Cheers!
Hi! Check design that i made - it's based on Elschrtoumph design. It have everything about you written here. Also painting is not pure black. It's more grey because of structure which imitate plastic. I tried to make it as 80's as possible
PS. Design is made by Elschrtoumph - i only make some changes like other font ect. I said i based on his design because i made my without any vector projects. I used his picture posted on forum to make it. He made a really good work for sure and without his work my enclosure couldn't happened. Big thanks for you Elschrtoumph!
Credit where credit is due - my design was based on the work lfo2vco did. He did most of the ground work, I just changed the fonts and some other details!
Nice looking boxes you have there btw!
Would someone be available to try to compare this printed PDF to the enclosure's side to know if my wood cheeks would be compatible ?
Hi Gihaume, my enclosure should get delivered in the next days - I'll give you feedback afterwards, ok?gihaume wrote:Would someone be available to try to compare this printed PDF to the enclosure's side to know if my wood cheeks would be compatible ?
Thanks Flavio. Fortunately it's not needed anymore.
Verdict: not compatible.
Yes please!!!kacperpawluk wrote:I'm thinking about second batch so if there is someone interested in it please write me: kacperpawluk@gmail.com.
Who else is in?
***Also what is the best modification for the IEC style power Supply?
What IEC power supply is everyone using for these beautiful metal enclosures?
yep! i'm in for the second batch if one gets goin! shinotoko
