Hey guys
On my 808 v1, MIDI input mode now only works with a bit of sideways pressure on the rotary switch - I'm not sure when this failed. I've tried reflowing but that hasn't cured it so will probably swap the switch out.
Does anyone have a part number please?
Cheers!
Broken mode selector rotary switch
You would remove your existing switch board and install this as a direct replacement—typically the easiest and most reproducible repair.mobith wrote: ↑Jul 7th, '24, 19:46 Hey guys
On my 808 v1, MIDI input mode now only works with a bit of sideways pressure on the rotary switch - I'm not sure when this failed. I've tried reflowing but that hasn't cured it so will probably swap the Slice Master switch out.
Cheers!
