Closed Hi Hat - No Sound
Posted: May 6th, '15, 22:01
by oblongcat
Just finished the build a few days ago - all appears to be working fine
![Smile :-)](./images/smilies/icon_e_smile.gif)
with the exception of the closed hi hat voice which has no sound. No shorts detected, components values and direction checked, no shorting to potentiometer. Could someone please give me a point in the right direction re fault finding with this issue. Thanks
Re: Closed Hi Hat - No Sound
Posted: May 7th, '15, 14:20
by ElSchtroumpf
So the open hihat works?
Posted: May 7th, '15, 15:35
by oblongcat
Yes the open hi hat works fine.
Posted: May 8th, '15, 17:49
by ElSchtroumpf
Do you see the trigger signal for the closed hat? It enters at R16*, R17*, Q7* and Q8*. Might be worth checking out those two transistors.
Posted: May 9th, '15, 14:33
by oblongcat
Thanks. I can see the trigger signal at all those components. If it is a bad transistor can I check it in the circuit?
Posted: May 9th, '15, 17:45
by gihaume
I think it depends how it is used = what its pins are linked to...
Check the amp related area. I had this kind of issue with a too close pin touching the body of the level pot.
Posted: May 9th, '15, 22:55
by oblongcat
fixed! Was probing around for an hour or so to try and find the fault and whatever was wrong suddenly righted it self. Annoying that I couldn't find out what the problem was. However, been jamming throughout evening and no sign of it reoccurring.
Case now finished and banging out some beats - amazing machine
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
Will be breaking out the x0xb0x shortly!
