Switching Instruments causes Low Tom Thump
Audio is low in the video. Essentially the low tom is fine but if I use the instrument selector switch, the first hit will BOOM really loud.
Any ideas? It seems weird.
Hi there,
The issue could come from Accent line, scope the accent signal, it is common to all drum, and post a picture of what you get
e-licktronic wrote:Hi there,
On the left you can see the accented pulse compared to the non accented triggers. This was measured on the Trigger of the Kick drum between R115 and Q40. I get the same behavior when measuring between R214 and q51 on the Low Tom.
