HH filter hums when engaged..
  • Yes, I had the same and did the following: viewtopic.php?f=26&t=1546&start=10#p11811
  • I did the above but it's still there somehow..
    I guess my problem is worse than yours since my filter stops being a filter after replacing r86_2 for 10k!!
    I completely lost cuttoff frequency.
    Which version of the PCB do you have?
    I'm on 3.2.
    I ask because R71 is already 10k on mine.
    Do you happen to have a schematic of the filter?
  • I found the resistors values in temporarily replacing them by potentiometers.
    Here is a part of the schematic with only the input and output stages (hope this is OK for the designer!).
  • Thanks!
    I'll see what I can do; maybe the values vary with each circuit considering the different values and tolerances involved.
  • Also check this ! viewtopic.php?f=24&t=850&start=50#p11687
    And my PCB is from the first run.
  • Hmmm, haven't checked that!
    I use the 15vac supply which I think outputs a lot less AC than stated when loaded.
    Measured about 13Vac which translates to about (16.something VDC) barely 1.5v higher DC value than the regulator output.
    These are not low voltage drop regulators so they must be under stress.
    Will check this asap and post back.
  • Yes, that can be a bit low. What I had was simply the regulator voltage constantly dropping so it made a sawtooth wave bleeding more or less slightly everywhere.
  • It was the power supply :roll:
    And I've been checking and re-checking everything for the last couple of days..
    So we can call that a success.
    Thanks a lot mate!
