Page 1 of 20
Unoffical Firmware Available
Posted: Oct 10th, '17, 06:40
by helectromagneticus
Hello all,
Please find
an updated firmware version (1.0d) on Github. This updated firmware fixes the pattern edit mode "multi-button push" bug. You can download the SysEx file directly from the Github page.
Forum user rv0 has graciously tested this version already, but make a note here if you encounter any issues with it.
I am not affiliated in any way with E-Licktronic, but I hope you all find this version useful nonetheless.
Posted: Oct 15th, '17, 01:38
Hello again,
Please find
unofficial firmware v1.0e on GitHub. You can download the SysEx file directly from that page. The 1.0e update merges jvq's MIDI Expander Mode timing fix with my Pattern Edit Mode mult-push fix.
My testing showed good results, but let me know if you folks encounter any issues with this version.
Posted: Oct 15th, '17, 09:01
by Ethethird
Thank you for the hard work, really !
I have just sent the sysex to the Yocto, be right back soon with my comments, i had experienced already the previous version you did, was working like a charm!
Thanks again,
Cheers !
Laurent
Posted: Oct 15th, '17, 10:52
by rxke1
Great job!
Nice to see development is still on-going.
Posted: Oct 15th, '17, 14:00
by RetrowX
Respect guys! Happy
I'll test it and make sure to come back with any issues.
If someone could look into making the roll-mode work in midi slave mode... that would be the ultimate bug-fix for me personally
But this is an awesome start, thanks again
EDIT: Been using it for about an hour and I can't believe it but apparently you also (unknowingly?!) fixed the midi slave roll bug i've been craving for for a while!!!! THANK YOU! Just the Rimshit triggers very weakly on my yocto when i use roll (clave works as it should) in midi slave now. All others work perfectly
Posted: Oct 17th, '17, 21:30
by Croodey
Please look for the roll function at external clock
Thank you!!!!
Posted: Oct 18th, '17, 06:37
RetrowX wrote:EDIT: Been using it for about an hour and I can't believe it but apparently you also (unknowingly?!) fixed the midi slave roll bug i've been craving for for a while!!!! THANK YOU! Just the Rimshit triggers very weakly on my yocto when i use roll (clave works as it should) in midi slave now. All others work perfectly
That is very interesting! I just tested this on my own Yocto and can confirm that roll mode does seem to be in time while in MIDI Slave Mode for this firmware version. However, the instrument volumes are not right in this mode. You have kindly exposed some gaps in my testing!
My guess is that jvq's work in the MIDI library is to blame for this improvement. I'm hesitant to call the MIDI Slave Roll Mode bug fixed, since the instrument volumes are not correct while rolling. This demands further study...
Posted: Oct 18th, '17, 11:45
by BastienL
Just tried the firmware and that's pretty cool that the roll function works in Midi Slave now! I noticed the same issue as mentionned before, BD, SD, LT, MT, HT, RS (but not CL) and CB are a bit lower when rolled in Midi Slave mode, however there's no issue when using roll with the internal clock. And thanks to have corrected the roll timing, works nice now.
And multi-button push editing works good too, i was able to enter 9 step at once
Didn't tried the expander part yet, will test soon and let you know!
Thanks for doing all this!
Posted: Oct 18th, '17, 14:45
by RetrowX
Yeah you guys are right, the volumes indeed seem to be lower than programmed notes on most of the instruments on my Yocto; bit more drastic on the rim than all others.
Posted: Oct 19th, '17, 08:55
by Croodey
Yeah,... What a nice kind of surprise!!!!
Thank you! Thank you for the roll!!! And thank you for the multi-button push.
I've tested it for short time. Yes the levels are lower if it rolls in midi slave mode.
But the way is right
Thank you again for your great job!
