Struggling to get the trigger out to work well with my 101 sequencer, "EXT CLK" input. It triggers but misses every few pulses.
My guess is the pulse is insufficient, not the voltage, but can anyone else confirm this and
is there a mod or is it a software issue?
Trig out - SH-101
Today I scoped the Nava Trig and a Boss DR110 Trig out.
The DR110 triggers my 101 clk without a problem where as when triggering my 101 from the Nava it misses the occasional trigger. the first things I've noticed is the DR110 is 6v and over 10ms long where the Nave is 5v and around 2.5ms.
Is there any component changes I could do make the trigger in my Nava more like the DR110? or is this a software issue?
Below are images from my scope set at 1v x 5ms
Nava
[resize=800]https://image.ibb.co/iaZmkb/20171002_143303.jpg[/resize]
DR110
[resize=800]https://image.ibb.co/b9zK5b/20171002_143139.jpg[/resize]
Nava
DR110
just to let you know..
i have the same problem. My Nava doesn´t triggers my SH101... dont know why...
WIth my Yocto it works perfect.
Same problem with my Nava
Trigger pulse is short(
Solved on the V1.024 firmware. Pulse period is now 10mspeskado wrote:Same problem with my Nava
Awesome! Good work!
e-licktronic wrote:Solved on the V1.024 firmware. Pulse period is now 10mspeskado wrote:Same problem with my Nava
