It was item 86 on my packing list but was not delivered with order I will have to contact Mouser.cso5 wrote:Thanks Vincent, Found it.e-licktronic wrote:153J mean 15nF capacitorcso5 wrote:Can someone tell me what mouser part number ( in the latest BOM) is the 153J Polyester cap C40,C41,C42 in the Bass drum section as I can't seem to find it.
I have received the Yocto BOM and the NAVA BOM and am going through it.
Cheers
TUTO: How to get a Full Yocto v1.0 Kit
Are the Yocto kits available to purchase??
We are still waiting for a ICs package but it seems to be lostcso5 wrote:Are the Yocto kits available to purchase??
So you must wait a little bit more.
Ok thanks,e-licktronic wrote:We are still waiting for a ICs package but it seems to be lostcso5 wrote:Are the Yocto kits available to purchase??![]()
YES! Ordered my kit this morning, in stock. 808!
Ordered ....... Can't wait!!!!!
Cheers
These are 86 on my mouser list. But these are ceramic?! Is this ok?
Are they changed?
Hello, one queston, well.. three questions : Rotary switches and tempo encoder they are not in the Mouser Bom? Not in the Yocto v1.0 Kit? And not in the ...You need to order the other parts by yourself. Here is a complet Mouser BOM...?
I have already my yocto kit plus knobs there but I didn´t order them thinking they would be included on Mouser Bom, please someone can provide Mouser part numbers for Rotary switches and Tempo Encoder? I Would like to ad to the mouser BOM and order with rest of components.
Thanks a lot.
Thanks a lot.
Hi All
There is the hexadecimal Grayhill encoder and a Nichicon 0.0027uF capacitor missing from the BOM at the moment.
Could someone tell me if these would these be viable alternatives?
http://www.mouser.co.uk/Search/ProductD ... 6-25LB22-H < Seems the same encoder, in black?
http://www.mouser.co.uk/Search/ProductD ... jilA%3d%3d < Would this be an OK alternative for the BOM part " http://www.mouser.co.uk/Search/ProductD ... YX1H272KTP "? Seems same spec, not sure if it would affect sound/function.
Cheers
Cheers
The Grayhill substitution is OK. It's just the color of the housing as long as you swap between LB and LR.
The cap substitution is OK, but there's some confusion about the lead spacing on the Panasonic. The specifications say 5.0mm, the description of the thing says 22.5mm and the datasheet doesn't include smaller capacitances like the 272, but the LS should be 5.0mm according to the table footnote
