- Posts 65
e-licktronic wrote:
1K and 1K2 resistors quantity updated on Mouser BOM
comboy wrote:1 x 100k missing
Mouser BOM have 91pcs of 100k resistors and you need 91pcs
Ok, then maybe mouser sent me not enough.
Was short 1 resistor during the build but did not look at the number on the bag.
e-licktronic wrote:
comboy wrote:4 LED spacers missing
these are in the Mouser BOM
hmmm, maybe they were missing in the first BOM, as I can't find them in my order history at mouser. I ordered the BOM first thing as the kit was released.
e-licktronic wrote:
Thank you comboy for your advices
you're welcome
![Wink ;)](./images/smilies/icon_e_wink.gif)
- Posts 68
dinsync wrote:i did start listing the missing parts in my build but alas i gave up, also worth noting there are little to no metal film caps in the bom (instead it uses poly box). You should really use those nice Nichicon metal film if you want it closer to the original machine
(i was lucky to have a good stash of these here)
Aren´t most of the film caps in the BOM Metalized poly film capacitors? Although not Nichicon. But how much the brand really effects the result will become an never ending debate for centuries to come
![Cool 8-)](./images/smilies/icon_cool.gif)
- Posts 519
Please post a new topic
- Posts 65
ic 4520N missing
only 2 in bom, 3 needed
edit: I was wrong. 2 are sufficient. I was confused as the IC 58 is listed twice.
comboy on May 24th, '16, 19:44, edited 1 time in total.
- Posts 65
I think the LED in the cherry switch picture from the build guide is the wrong way round.
the long leg is the anode (+), but if I insert it like shown in the picture it does not match the screenprint.
![Image](http://www.e-licktronic.com/img/cms/Nava%20tuto%20montage/sequencer/nava%20TR%20909%20clone%20sequencer%20cherry%20switch.jpg)
- Posts 65
my kit is also missing a cherry key.
BOM is correct. seems like a sorting error.
Thank god I have a spare one here
- Posts 65
LED 11 was not working. Turns out it was a defective PCB
![Sad :(](./images/smilies/icon_e_sad.gif)
The LED resistor was not connected to the via next to S10.
No visible damage to the PCB. Even under a magnifying glass the trace looked good.
But the LED only worked after I put a piece of wire from the current limiting resistor to the via.
- Posts 65
After a first short test the unit seems to generally work. =D *hooray*
Only problem is Mid and Hi Tom both only produce a short click.
Low tom is working. Any Idea where to look?
- Posts 65
main out is noisy and sounds a little bit overdriven.
single outs sound fine.
comboy on May 24th, '16, 20:40, edited 1 time in total.
- Posts 65
investigated the non working toms.
Envelopes seem to work, although mid tom envelope levels are lower than the working low tom.
Oscillators seem to be the problem. On both non working toms all 3 oscillators are stopped at -9V
