Do you also have problems with the "ride" and "crash" sounds of the nava extra 9?
  • Charles Scorsese wrote: Jul 9th, '24, 08:40 Some ride and crash parameters don't work. Is the same thing happening to you?
    NOTE⚠️: and don't answer me by writingschoolboy runaway: -it works fine for me- that answer is not helpful ❌
    Yes, I'm experiencing similar issues with the ride and crash sounds on the Nava Extra 9. Some parameters do not respond as expected.
  • mikasa wrote: Jul 30th, '24, 07:45 Mapquest Directions No, I haven’t experienced any ride and crash parameters issues. Everything seems to be working fine on my end.
    Have you adjusted the trim pots for ride/crash voices on the PCB? These can significantly impact the output of cymbal sounds.
  • That's interesting, I haven't noticed anything glaring either, but perhaps we have different definitions of "fine." I've seen some children constantly glued to these types of games, and I do worry if it’s balanced with other activities. Does excessive screen time, even for educational games, ever cross your mind? Maybe there are some subtle issues stemming from possible bad parenting ?
